Michigan Apollo 4-Blade Prop, Exchangeable Hub / SS, 14 dia x 22, LH
High performance stainless steel Apollo propeller with an exchangeable hub system! The Apollo propeller is a proven combination of performance and durability that will wake up your sterndrive or outboard. Michigan Wheels Xchangeable Hub System absorbs impact and stress caused by shifting gears and is designed to spin under significant impact to protect your lower end unit. XHS is also designed to be interchangeable with Mercurys Flo-Torq II hub system, making it a great choice for a replacement or spare prop. Backed by Michigan Wheels limited lifetime warranty. Propeller and Hub Kit sold separately. Michigan Wheel Apollo XHS Propellers must be used with XHS hub system or Mercury Flo-Torq hub system. This Apollo XHS Propeller is the prop housing and blades only. XHS Prop Series A: For use on V6 (4-3/4" Gearcase) Outboard V6/V8 I/O applications Michigan Apollo Part #: 993.
Michigan Apollo 4-Blade Prop, Exchangeable Hub / SS, 14 dia x 22, LH Review
No doubts, that Michigan Wheel is one of best producer of this propellers. All of my mates tell me, that I must buy Michigan Apollo 4-Blade Prop, Exchangeable Hub / SS, 14 dia x 22, LH. The earlier I buy it, the better it is.
